Time Zone Handling for CSV Load
Each date in a CORE date field is expected to have a time zone. For those dates that are lacking a time zone, you can specify a time zone or use the crawler host time zone.
This is done for any CSV date field that you map with a CORE date field in the wizard or that you map using a date type in the data source configuration.
Use the crawler defined default time zone
Field mappings
Missing Time Zones Handling
