Undo Deletion
As long as the index engine is not saved, you can undo document deletion.
- In CORE Administration, on the Explore tab, search for all documents.
- In the
Filters list, select
Special criteria, and then activate the
Include deleted documents in a search check
box.
The documents marked as deleted are now also shown in the Document Result List.
- In the Actions menu, select Mark documents as active.
This removes the
deletion mark from the documents in theDocument Result
List.
