Get Started for Administrators
After installation, the first task of an administrator is to set up a project. A project includes the applications that you need for early case assessment and for document review.
Project setup in Axcelerate Cloud with LaunchPad
The standard project setup in the cloud is via LaunchPad. Launchpad assists you in creating all needed applications and in creating users and user groups with their privileges. Storages use Amazon S3 technology.
Using Axcelerate Cloud, you do not have to care about server architecture or maintenance. Recommind cares about server performance and storage space when your project is growing over time.
Setup for on premise installations
Before any installation, you plan for servers and server roles required. Recommind Support will assist you in planning system architecture. Axcelerate 5 provides tools that allow you to monitor server performance and storage space when your system grows over time. Storages are file-based by default.
Other setup types
For non-standard setups, such as file-based storages in an Axcelerate Cloud system, ask Recommind Support.
