Log Levels
Log levels determine the importance of information contained in a log file. You can configure log levels for some files.
Important: Using a higher log levels than the default levels may result in loss of performance.
Different log levels provide different content:
  • For index engines and crawlers, log levels include the C++ side.
  • E3 and E4 C++ log entries are written directly into the log files.
  • E1 and E2 exceptions are handed over to the Java side and marked as a CPP exception.
Level name Log level Property Description
Off   no logging
fatal E1
Logs fatal errors only. Messages up to [E1] are logged.
error E2 Logs all errors and fatal errors. Messages up to [E2] are logged.
warn E3
Logs all information about possible issues. Messages up to [E3] are logged. This level is the standard level for all appenders (components that write log messages to files or the user interface). Use this log level for systems in operation.
info
I1 - I4
Logs all information in detail. All error and information messages up to [I3 or I4] are logged by default. (See also Changing Log Levels for Engines and Data Sources .)
debug I5 Logs all information in great detail. All messages up to level 5 are logged. This level is only used for developer debugging and may significantly impact performance.
all   All messages.
