Applications for Amazon S3 Storages
Applications for Amazon S3 storages have their own preconfigured templates.
- For Axcelerate Ingestion application
- documentHold.sytemTemplate-Axc5-v1-AWS
- For Axcelerate Ingestion index engines
- singleMindServer.documentHoldSystemTemplate-v2-AWS
- For an Axcelerate Review & Analysis index engine
- singleMindServer.axcelerateStandaloneSystemTemplate-Axc5-v2-AWS
Important: We recommend to not change the template settings for storages, except for Amazon S3 access.
Default storage properties
- In Amazon S3, data is not stored in files, but as binary objects in the cloud.
- The Amazon S3 connection is configured in the CORE master service. All applications managed through the same master service use the same Amazon S3 bucket for storages.
- Scalability: Amazon S3 does not set any limit to storage sizes.
- Axcelerate Ingestion and Axcelerate Review & Analysis use primary storages, that is, deleting an application does not affect other applications using the same stored files. Also, applications do not use an external storage by default.
Storages are SQL-managed. SQL-management in combination with Amazon S3 storage offers:
- single instance storage, that is, file sharing within one storage handler
- external cloning, that is, file sharing between different storage handlers.
- case-wide sharing of native files
- compressed storage of native files and redactions
What does this mean for native files and images?
- Native file copies are created for any type of data loading, including CSV data load. A reference to these native file copies is added to the Axcelerate Ingestion storage handler. During publishing, a reference to these native file copies is added to the Axcelerate Review & Analysis storage handler.
- Image copies can be imported with CSV load or CSV merge. A reference to these image copies is added to the respective storage handler. During publishing, a reference is added for the Axcelerate Review & Analysis storage handler for images.
