Audit Logging for CORE Administration
Audit logging is the automatic, chronological logging of user actions. Audit logging results for the CORE Administration user interface cover, for example, starting and stopping components, configuration changes, and changes to user security. They are stored in the UserActions.csv file in the %MINDSERVER_PROJECTS%\adminTool.admin\WEB-INF\Logs\Audit folder.
Audit logging is enabled by default. To disable it, open the configuration of the admin application in CORE Administration and, in the Project parameters node, clear the Audit Logging check box.
A new audit log file is created every month. The content for the last month is stored as UserActions.csv.<timestamp>.
Event name |
UI Action |
add | Actions menu: Create workspace, Create application, Import application, Add document model, Add engine, Add data source |
automatedCreation | Roles tab for servers shown on Computers panel: Select/Clear Ready for automated creation |
autostart | Details tab: Select/Clear Autostart |
autoSuspend | Details tab for an application: Select/Clear Suspend automatically |
change | Details tab: Change to Description field |
clear | Actions menu for index engines: Clear project |
configure |
Save the configuration (with or without changes), Actions menu: Clone field for a document model, Actions menu: Reposition fields for an application |
context |
Details tab for a stopped application: Change to Context field |
displayName | Details tab: Change to Display name |
dropTemplate | Actions menu: Drop Template |
globalTemplate | Details tab: Select/Clear Use as global template |
heap | Details tab: Change Java heap size |
https | Details tab: Select/Clear Use HTTPS |
inactive | Actions menu for an application that is not running: Set to inactive |
javaParameters | Details tab: Change Java parameters |
remove | Actions menu: Remove |
restart | Actions menu: Restart |
Security events: addUser, removeUser, modifyUser, addGroup, removeGroup, modifyGroup, removeUserFromGroup, assignGroupToApplication, assignUserToApplication, assignUserToGroup, assignRole, removeRole | Actions on Security panel or Actions menu for an application: Grant access, Configure roles Note: Security changes made in the application 's Configuration window are logged as |
setTemplate | Actions menu: Set Template |
shutdown | Actions menu: Stop |
start |
Actions menu: Start Any other control that starts a component |
stop | Actions menu: Kill |
writeLock | Actions menu for index engines: Apply write lock/ Apply write unlock |
