ExpeDat Configuration
You can optionally configure the network and apply limits so the bandwidth utilized by Expedat will not interfere with other network traffic. Click the Opt button in the middle of the screen to open the Options dialog box and then select the Limits tab to access and configure these settings.
Note: Rate-limited client versions are also available to limit the ExpeDat bandwidth usage. The current versions are 2Mbps, 5Mbps, 7Mbps, 10Mbps, 15 Mbps and 20Mbps. If you require a rate-limited version, contact your Axcelerate Cloud Implementation Team.
