Type-Ahead Field Threshold Settings
To configure the Axcelerate 5 pod-wide threshold settings for type-ahead fields, you need access to the web tier properties file on the main server.
Open the %MINDSERVER_HOME%\AXC5\properties\webtier.user.properties file.
- axcng.taxonomies.large.default.size.min=<number>
- Single value, multivalue and hierarchy fields that reach this number of values automatically convert to a type-ahead display in the Axcelerate 5 front end. Allowed values: 0 - 2147483647Default value:
- 2147483647 (Integer.MAX_INT)
Note: On an Axcelerate 5 application-level, a field can be converted to a type-ahead display even if it does not have the required number of values. This configuration setting is available on the Axcelerate 5 Fields and Values page.
- axcng.taxonomies.large.default.viewsize.max=<number>
- When a user clicks in the text box of a type-ahead field in an Axcelerate 5 tagging panel, a drop-down list shows this number of field values. If the desired value is not displayed, the user can search for the value. Allowed values: 1 - 2147483647Default value:
- 30
Tip: We recommend a low number for this setting, to keep these types of fields fast and responsive.
- axcng.taxonomies.large.default.preview.max=<number>
- When a user accesses the Values tab for a field on the Axcelerate 5 Fields and Values page, only this number of values is displayed for preview and editing. Users working on that page do have the option to load all values.Allowed values: 1 - 2147483647Default value:
- 1000
Tip: We recommend a low number for this setting, so a user accessing this page does not experience web browser unresponsiveness.
