CORE Log Viewer
The CORE Log Viewer provides a way to view, search, and filter log files for index engines and data sources that are located in the same workspace in CORE Administration.
The CORE Log Viewer is an application that you can access from the Workspace panel in CORE Administration. It is located in the Default workspace.
This section describes how to use the CORE Log Viewer and its features.
