Proximity Search
Sometimes called near or within searching, proximity search looks for terms that are not more than a certain number of words apart.
/n
Replace n with a number to locate terms that occur within the specified number of words from each other, regardless of word order.
/p
Connects terms to be found in the same paragraph regardless of word order (that is, within 15 words by default unless modified by your administrator).
/s
Connects terms to be found in the same sentence regardless of word order (that is, within 5 words by default unless modified by your administrator).
pre/n
Replace n with a number to locate terms within the specified number of words from each other, where the first term always precedes the second.
pre/p
Connects terms to be found in the same paragraph (that is, within 15 words) where the first term always precedes the second.
pre/s
Connects terms to be found in the same sentence (that is, within 5 words) where the first term always precedes the second.
When using proximity search, keep in mind:
  • Always separate an operator from its parameters with a space.
  • Count stop words and the ending word when determining the proximity separation number.
  • A phrase is considered as a single word.
  • Terms must be at least one term apart; a /0 proximity search will return an error.
  • Do not add a w before the proximity operator, for example, w/2, as the added character will cause the search to return inconsistent results.
  • Proximity expressions are always executed in exact match mode.
Stop Words
