Exception Types Reference
- Access denied
- If found with class: Access
- Access to original files failed, or writing temporary data during buffering failed.
- If found with class: Unexpected
- Reading failed for temporary files during buffering.
- Archive entry processing
- Content modified
- Often found with class: Corrupt
- Corrupt archives might need a fix. Password protected or unsupported archives might need external extraction or conversion.
- Attachments removed from Native
- This exception marks corrupt attachments to Outlook mails. When a native file is created, corrupt attachments are omitted.
- Content size not applicable for connector
- Often found with class: System, Not supported
- Data is too big to retrieve, e.g. data is likely to produce an out of memory exception.
- If a file size limit is defined for the connector, — and, maybe, also for a parser — change it and re-crawl.
- Corrupt Outlook item property
- System failed to decode a value, due to an unknown encoding in an Internet header.
- The encoded parts that cannot be read are ignored. There may be some email display addresses missing. E.g., if the complete email address is "Niklas Müller" <niklas.mueller@rheinbach.de>, Niklas Müller may be missing. Document content is not affected.
- Crawler out-of-memory
- Often found with class: Fatal
- This normally comes along with a
FatalCrawlErrorthat is logged in the crawler.log file and that will stop the whole crawler. After an out-of-memory, the system is too instable to proceed. - Depending on the out-of-memory reason, one of these actions may be recommended:
- Configure less threads in the data source configuration, in the Threads node.
- Add JVM arguments that allow more time for cleanup by the garbage collector. Add them in CORE Administration, on the Details tab for the data source.
- Exclude critical documents in the data source configuration, in the node.
- Adjust the size limit for the parser in the data source configuration.
- Adjust the size limit for the connector in the data source configuration.
- Csv parser error
- The content of a field in the CSV load file is not compatible with the mapped field in (Undefined variable: recommind_products.Ing application). This might be, e.g., a date field that has invalid content, or a wrong reference to native files.
- Database processing
- Often found with class: Corrupt, Not supported, File format
- Database protocol exceptions, e.g. a connection to Notes, Domino, or a JDBC-based database (like Ringtail, Worksite,...) fails, or SQL statements are wrong or cannot be transmitted.
- If a connection failed, re-establish it and reprocess the files.
- Datasource problem
- Often found with class: various classes
- Unexpected record/item found.
- Date Parsing
- A reason for this may be that the date format is not known.
- In the data source configuration, in the Date settings node, add it to the Input date format table.
- Directory not found
- Often found with class: Access
- Missing directories in file system, database, or archive.
- Disk full
- Writing temporary data during buffering failed due to full disk.
- Change data source server or add disk space.
- Document in use by other application
- Often found with class: Unexpected, Access
- Reasons may be:
- Read or write fails for temporary files during buffering.
- Read fails for original data during buffering.
- Anti-Virus software may be processing the item. Exclude the crawled directories from anti-virus scanning.
- Document too large for indexing
- Data exceeds a certain limit. In such cases, the system automatically starts an indexing re-try for the metadata only and omits the content.
- You can change the internal configuration option Maximum peak memory usage in the index engine configuration, in the node.
- Document too large for parser
- A maximum document size is exceeded.
- Possible resolution: Change the size limit or byte input for the respective parser in the data source configuration, in order to avoid OOM exceptions.
- Engine out-of-memory
FatalCrawlErrorthat will stop the index engine and, consequently, the crawler.FatalCrawlErrorwill be logged in the engine or crawler log files. - Error during communication with MindServer
- Reasons may be:
- connection problems between crawler und engine
- CORE system issues that have an impact on the crawler
- Error during post-processing
- Post processing of parsed/resolved data failed, either due to data source misconfiguration, in the Property Postprocessing node, or due to internal problems during XML document creation.
- Check and correct Property Postprocessing settings, if possible, or contact Recommind support.
- Error during SQL execution
- Often found with class: Fatal or others
- SQL errors are critical and can mean large data losses.
- Error in native code
- Possible reason: incorrect installation. Read the Exception field.
- Error resolving URI
- Resolving URI failed. This is a critical issue, because a huge amount of data may be missed.
- External process execution
- Exceptions produced by third party or external processes/services etc.
- File corrupt
- File is corrupt. If the file is a MSG or PST file, run
PSTValidator.exefor details. - File not found
- Often found with class:Unexpected or Access
- Standalone file or archive entry not found.
- General storage error
- Native files could not be stored in the configured storage.
- Getting storable data failed
- Exception for fetching storage data
- Examples:
- A native file could not be created (e.g. for parsing wiht the DXL or CSN parser).
- A native file was deleted between parsing and storing.
- A native file could not be opened/read.
- Invalid characters
- Often found with class: File format, Corrupt and others
- Examples:
- Wrong character sets in emails
- Binary data in body text.
- NULL characters or control characters in body text.
- Invalid XML
- Error in producing indexable XML file.
- This exception should be avoided by the system, but is sometimes caused by corrupt emails.
- Contact Recommind support.
- Job exception
- This exception can be thrown by the crawler job framework. Exceptions can be runtime exceptions, for example.
- For more information on a job exception, look up the crawler.log file or ask Recommind Support.
- Large junk percentage
- File contains large percentage of junk characters, detected by junk detectors, e.g. BASE64.
- MIME types checked for junk characters are listed in the data source configuration, under
- MIME type could not be detected/set
- MIME type detection failed.
- Possible reasons:
- File is corrupt or has an inadequate file extension.
- A MIME type detector is misconfigured. Check in the data source configuration, under
- Miscellaneous error
- Exception is difficult to identify. Ask Recommind support.
- Miscellaneous errors resolving resource
- Often found with class: Unexpected, Fatal
- If resolution of data source URI fails, a fatal error is only logged in the crawler.log file. No documents will be indexed.
- Another reason my be a connector or parser exception, e.g. server is not accessible, 404 page not found.
- Miscellaneous indexing error
- Exception is thrown by internal crawler components. More information can be found either in the crawler.log file or in the exception document.
- Miscellaneous I/O error
- Found with class: Unexpected
- This is often a buffer exception. Reading temporary data failed.
- Found with class: Access
- This is often a buffer exception: Reading original data or writing temporary data failed.
- Miscellaneous parser error
- Exception during document parsing.
- Not supported
- File format that none of the parsers supports.
- Parent document PGP secured
- Often found with class: Password protected/encrypted
- Used for attachments of encrypted PGP MIME messages. PGP stores the encryption in an attachment. The attachment is tagged with this exception type.
- Password protected files
- Encrypted and password protected data are not searchable and not readable.
- Can be combined with PGP or S/MIME exceptions.
- PGP encrypted
- This exception is only shown if the PGP detector is enabled.
- An email only contains encrypted PGP content. PGP encrypted content and signature are removed by default.
- No action is required, except if you can decrypt PGP externally.
- This item is suspected to have caused a crash in the last run. It is skipped in resume mode.
- Often found with class: corrupt
- This exception occurs if a file that cannot be processed causes the data source crawler to stop, and if the crawler automatically resumes afterwards.
- S/MIME encrypted
- Flags S/MIME encrypted emails if S/MIME certificates have not been imported.
- You can import certificates and then re-crawl the emails.
- SOAP message oversized
- Exception for large messages that cannot be handled, thrown by the optional Mindserver SOAP interface.
- SOAP message zero size
- Exception for empty messages thrown by the optional Mindserver SOAP interface.
- Stellent
- Stellent is not able to open the file. Temporary files like ~wm54154.tmp that are automatically generated, can be the reason.
- Storing data failed
- Error for missing write access to store data.
- Stream access
- A connector’s data access via remote connection is affected.
- Read the message in the Exception field.
- Temp file access
- Issues with temporary files.
- Timeout
- Often found with class: Timeout
- Timeouts can be configured in the data source configuration for some connectors or parsers, and in the index engine configuration.
- Traversing links
- This may be an exception for traversing issues, missing items, "get next", etc.
- There may be large amounts of data missing if this exception occurs.
- Unknown MIME type
- Possible resolution: You may enable another detector in the data source configuration.
- Unsupported MIME type
- A MIME type that does not figure on the supported MIME types list.
Important: Special attention is needed, as exceptions of this class may result in a large number of missing files.
Note: If you are not sure about the action to take, ask Recommind support.
