Axcelerate 5 Navigation Page
When you log into the Axcelerate 5 front end for the first time, you see the Navigation page, which lists all published and unpublished matters. The TYPE column shows R&A for published matters and ECA for unpublished matters.
You can tag favorite matters. You can sort the list by any column. You can filter and search the matters using the Search panel.
The STATUS column indicates whether the application hosting the respective matter is running. The information for the Navigation page is collected every two minutes. Therefore, it can take up to two minutes until it shows on this page after a matter is stopped or started.
Matters in versions prior to Axcelerate 5, as well as Axcelerate Ingestion databases in Axcelerate 5, are shown as running if both the index engines and application are running. Matters in Axcelerate 5 are shown as running as soon as the respective index engines are running. The status of the application, which provides access to the Axcelerate Analysis module, is not checked.
Click the name of any running matter to open it.
Axcelerate 5
matters are opened in the same window. To return to the Navigation page, click to the left of the matter name.
From the Navigation page, you can also click on the page name to access the Processing and Business Intelligence pages.
Note: Axcelerate 5 front end retrieves the URIs for the modules from the master service. The URIs used to access the modules are configurable.
