mergeCsv script
Synopsis – Usage information
mergeCsv.bat|mergeCsv.sh [-help]
Synopsis – mergeCsv
mergeCSV.bat|mergeCSV.sh
- -project |-p <project name> [-host <host name>]
- [-port <port number>] [-servicePort <port number>]
- -session <session ID> or -user |-u <user name> -password|-pw <password>
- [-dump]
- -file <filename> [-expandFamily] [-dryRun]
- [-noFlushBefore] [-lockChanges] [-noFlushAfter]
- -append [-noDedup] [-forceChange]| -replace [nullValue <nullvalue> ]
- [-dontChangeProtected]
- [-noUniqueMatch]
- [-maxCategoryLength <number of characters>
- [-allowUpdateMultipleDocs]
- [-fieldsForDisplayNameAsId] [-displayNameMappingErrorFileName <exception log file name>]
- [-csvFieldNative <csv field name for path to native file>] [-nativeBasePath <filepath>]
- [-csvFieldImage <csv field name for path to image files>] [-imageBasePath <filepath>]
- [-storeOriginal <undo file>] [-exceptions <log file>] [-showMatches <matches log file>]
- -idCsv <csv field name> -idEngine <engine field name>
- [-idPrefix <prefix>] [-idPostfix <postfix>]
- -fields <csvField Name> <engineFiledName> [<csvFieldName <engineFieldName>] ...
- -fieldSeparator <separator> [-lineSeparator <separator>]
- [-multiValueSeparator <separator>]
- [-textIndicator <text indicator>]
- [-lineSeparatorForText <separator>]
- [-charset <charset>]
Reference of basic parameters
| Parameter | Value | Description |
-help
Displays information on command line utility. | |
-dump
Allows
to test the command without executing any commands in the
CORE
system. The possible result is displayed in the command prompt and you can
check if the result meets your purpose. The
-dump parameter must be added after all other
parameters at the end of the command line.
-project
<project name> |
The engine name.
Tip: The name has to be entered exactly as returned by
servicecontrol -user admin -password <password>
-getRunningProcesses.
-application
<internal application identifier> | Internal identifier as shown on the application’s Details tab in CORE Administration. |
-host
<host name> | Host ID of the CORE project. If omitted, the local host is assumed. |
-port
<port number> | RMI port of the CORE project. If omitted, port 1099 or the port specified as %MINDSERVER_PORT% is used. |
-servicePort
<port number> | RMI port of the launcher service. By default, this is 1099. If omitted, port 1099 or the port specified as %MINDSERVER_PORT% are used. |
-session
<session ID> | Session ID of a previous command; mandatory, if no
user and password parameters are given. This will only work if a previous
script command did not close the session, i.e., if that command contained
-noLogout. The session ID is displayed in the
command line tool after a script has been finished. |
-user
<username> | Mandatory, if no session ID is provided. |
-password
<password> | Mandatory, if no session ID is provided. |
-noLogout
By default, a session is closed when a script is
finished. With this parameter, the session is kept open. This allows the
following script command to use the
-session parameter. The session is closed if a new
script command containing -user
and
-password parameters and not containing
-noLogout is run.
-allowleadinglongdash
By default, the script execution is aborted if any option is introduced with a long dash instead of the plain hyphen-minus sign - (Unicode 002D). To allow such other dashes for introducing options, add this parameter to the command. |
Reference of functions
One or more of the following function parameters may be specified.
| Parameter | Value | Explanation/Remarks |
| -file | <filename> | This mandatory parameter specifies the CSV file containing the changes to import. |
| -expandFamily | — | Activates
family expansion, i.e., the defined changes are applied to the whole attachment
family of the matching document.
Optional. Note: Only the first match will be executed. If a documet belongs to the attachment families of two documents matching to different lines in the CSV, the first match will win. |
| -dryRun | Switches
to the
dry run test mode that does not apply any changes.
Optional. |
| -noFlushBefore | Deactivates
the flush buffer operation that normally is executed before import starts.
Optional. |
| -lockChanges | Blocks
all engine operation until the import has finished. Any API call is suspended
until the import has finished, ensuring that no other process can change a
document while it is changed by the import as well.
Optional. |
| -noFlushAfter | Deactivates
the flush buffer operation that normally is executed after import has finished.
Optional. |
| -append | If
this switch is added, the values from the CSV file are added to existing
values.
The command line must contain either
| -noDedup |
Only used in append mode: Ensures that duplicate entries are not removed.
Example: If you merge the values
Yes and
Maybe into a field with the values
Yes and
Uncertain, with
| -forceChange |
Enforces changing a field content even if the old and the new value are the same. This can be used if related values like e.g.
| -replace | Replaces
the existing values of the respective document fields with the values from the
CSV file.
If
Can be used for native file and image updates and removal. |
| -nullValue | <null value keyword> | If you use
-replace in combination with
-nullValue, you can control how empty CSV fields are
treated. If the CSV field contains the null value keyword, existing CORE field
values are deleted. If the CSV field is empty, existing CORE field values are
not changed.
| -dontChangeProtected | Specifies that the operation should not change documents that are protected in Axcelerate ECA & Collection, because they have been published. | |
| -noUniqueMatch | Content
of the CSV key field does not have to match the complete corresponding document
content, but only a part of it. This match must be an exact match. If
specified, a document field containing "ABC DEF" will match the CSVfield
content "ABC".
This option can be used for all CORE fields, except for the document ID. |
| -maxCategoryLength | <number> | Maximum number of characters per field value. If exceeded, the merge of the respective row will fail. The default value is 128. Use 0 or a negative value to disable the length limitation. |
| -allowUpdateMultipleDocs | Allows
to update fields even if multiple matching documents are found.
If this option is not used, only the first matching document will be updated, and there will be an exception for the matching documents that were not updated. |
| -fieldsForDisplayNameAsId | < CSV field> [<CSV field>] ... | List of all fields
that contain value display names. These fields must be mapped to an index
engine field in the
-fields parameter.
If an unambiguous mapping of field value names is possible, values will be mapped. They can be in any level of a hierarchical field. If a new field value is added with the script, it will always be placed at the root level of a hierarchical field. Note: For hierarchical fields, it is recommended to create new values in the desired place before running the script. |
| -displayNameMappingErrorFileName | <exception log file name> | File for logging mapping exceptions in case of ambiguous display names. If value mapping exceptions occur, you can use this file to resolve them. |
| -csvFieldNative | <csv field name for path to native file> | Specifies which column in the csv file contains native file location. This setting also configures the system to use the correct native storage handler in Axcelerate Review & Analysis. |
| -nativeBasePath | <filepath> | Base path relative to which native file locations are given. |
| -csvFieldImage | <csv field name for path to image files> | Specifies which column in the csv file contains image file locations. This setting also configures the system to use the correct image storage handler in Axcelerate Review & Analysis. |
| -imageBasePath | <filepath> | Base path relative to which image file locations are given. |
| -storeOriginal | <file name> | Poupulates a CSV file with the original values of all fields that were replaced/appended to. This file can be used to undo changes. |
| -exceptions | <file name> | Creates an exception log file for changes. Especially, a log file lists all CSV file rows that have not lead to any changes. |
| -showMatches | <file name> | This file logs matches between rows in the CSV file and IDs in the engine. |
Reference of parameters
The following parameters define the content that is changed.
| -idCsv | <CSV ID field> | Specifies the field in the CSV file that is used
to find matching documents.
Mandatory. |
| -idEngine | <engine ID field> | Specifies the internal field name of the CORE
field that is used to find matching documents.
Mandatory. |
| -idPrefix | <prefix> | String of characters that is added in front of the ID key from the CSV file before mapping it against the engine ID field. |
| -idPostfix | <postfix> | String of characters that is added at the end of the ID key from the CSV file before mapping it against the engine ID field. |
| -fields | <csvField Name><engineFieldName>[<csvFieldName <engineFieldName>] ... | Introduces a list of field mapping pairs each defining a source CSV field and a target CORE field. |
| -fieldSeparator | <separator> | Character
or character sequence that separates the fields in the CSV file.
Mandatory. |
| -lineSeparator | <separator> | Character or character sequence that separates lines in the CSV file, if this is not the default CR/LF used in Windows files. |
| -multiValueSeparator | <separator> | Character or character sequence that separates multiple values within the same field in the CSV file. If omitted, a semicolon will be assumed as delimiter for structured view field values, and blanks will be assumed as value delimiters for non-structured view fields, e.g., comment fields. |
| -textIndicator | <text indicator> | Character that is used to enclose CSV file text. Separator characters that are enclosed with the text indicator are not interpreted as separators. If omitted, the default text indicator is double quotes. |
| -lineSeparatorForText | <separator> | Line separator used in text fields. If omitted,
the default
\n is used.
This field allows to use unicode. This is suited for large chinese data. Unicode requires less space than UTF-8. |
| -fileIndicator | <file reference indicator> | Prefix that indicates that a cell of a full text column references a text file. In the CSV file, the prefix must occur immediately before every unicode path. |
| -charset | <character set> | If the default UTF-8 is not used, specify the character set. |
Example:
In this example, a custom CORE
field with the internal field name
rm_cities is mapped with the
Places field.
CSV file to be merged:
Script command line:
Example:
The CORE p field is mapped to the CSV TextPath column. This column contains references to text files. References are preceded with FILEPATH as file reference indicator. The text replace any text existing in the CORE field.
ID;TextPath BAB_443;FILEPATH\\Server\FULLTEXT\00\83\BAB_443.txt BAB_565;FILEPATH\\Server\FULLTEXT\00\83\BAB_565.txt
Example:
ID;NativeFile BAB-443;c:\documents\meeting notes.txt BAB_565;c:\documents\agenda.doc
