CaseMap Integration
CaseMap integration makes documents, metadata and text extracts available in LexisNexis® CaseMap®. This feature is disabled by default.
If you send single or multiple documents to CaseMap, a link to the document is created in the Documents spreadsheet in CaseMap. Users with the appropriate rights can click this link to open the respective document in Axcelerate 5, on the Review page.
A selected text extract can be copied as a new fact to the CaseMap case. It is shown in the Facts spreadsheet. From there, a link allows you to open the respective document in Axcelerate 5, with the text extract highlighted. Creating a fact requires that the respective document is linked in CaseMap, too. This is done automatically.
In addition to documents and text extracts, you can send metadata to CaseMap. For documents that have been sent to CaseMap before, metadata can be updated, and new metadata can be added.
If a document or text is sent to Casemap, Axcelerate 5 calls a Visual Basic script. The script and any messages related to it are part of CaseMap.
This chapter discusses the following:
