Delete a Batch
Case Managers have the ability to delete batches if they are created incorrectly, have completed review or no longer require review.
A batch cannot have an In review status.
To delete a batch:
- Navigate to the Assignments page.
- Select one or more review batches.
- In the toolbar of the Results panel header, select Delete.
Note: To delete a single batch, you can also click in the Actions column and then select
Change assignee.
