Discussion Panel Feature Setting
- CORE Administrator
- All
- Case Manager
The Discussion panel is an Axcelerate 5 feature setting. The panel is active and available to all users by default.
To access the setting:
- Navigate to the Administration > Settings page.
- Select the Feature Settings tab.
- Use the Enable discussion panel check box to enable or disable the panel.
Note: Disabling the Discussion panel does not delete comments; comments are visible again if the panel is re-enabled. Comments are also visible at any time in the Document History panel.
