Quick Tags
Quick tags are predefined tagging combinations that can be configured by a Case Manager. When active, you can use them to quickly apply a tagging combination to a current document or to a selected document set, speeding review.
Quick tags are specific to individual tagging arrangements. Each arrangement can have up to eight manually configured quick tags.
The Quick Tag panel is located at the bottom of the Tagging panel. Active quick tags have colored number tabs.
A Case Manager may also enable the L and U quick tags. If enabled, these quick tag options display once coding has been applied to a document.
