Common Review Methods
The following are commonly used methods of review:
- Investigative review
- This review method is often conducted using analytics, search, Smart Filters and sometimes Predictive Coding. If Predictive Coding will be used, you need at least one universe, at least one review workflow, search based sets, and iterations.
- Manual review
- For this review type you need at least one universe, at least one review workflow and search based sets.
- Review with Predictive Coding
- For this review type, you need at least one universe, at least one review workflow, search based sets, and iterations.
- Complete Predictive Coding process
- This method of review uses Predictive Coding and includes review progress tracking. For this review method, you need at least one universe, at least one review workflow, a target review workflow, search based sets, and iterations. Additionally, you need an estimation sample to help you determine the quality of training results and when the review process should end.
