Export Specification
Exports from results lists and matter exports that you can run in the Axcelerate Ingestion module are possible in the following formats:
- Concordance
- CSV
- EDRM XML
This export format is adapted to the EDRM standard. It is not available in the Axcelerate 5 front end.
You can customize delimiters and separators in the export wizard.
The exports may consist of the following files:
Concordance | CSV | EDRM XML |
Concordance file containing
Encoding: Concordance format. Text qualifiers and paragraph line break characters are not UTF-8 compliant. | CSV file containing
Encoding: UTF-8. | EDRM XML file containing
Encoding: UTF-8 |
Opticon reference file for images.
Encoding: UTF-8. | Opticon reference file for images (if image
references are not written to CSV).
Encoding: UTF-8. | |
Text files that contain the content of the
indexed documents.
Encoding: UTF-8. | Text files that contain the content of the
indexed documents.
Encoding: UTF-8. | XML documents with document text and
metadata
Encoding: UTF-8. |
Images of the documents (if available) | Images of the documents (if available) | |
Native files of the documents (if available) | Native files of the documents (if available) | Native files of the documents (if available) |
Exported native files are named according to the numeric document ID. For example, a PowerPoint file with the numeric document ID
Mine01:00000049
is exported as
Mine01_00000049.ppt
For each export, the system generates a Transmittal report with statistical counts for the exported documents.
By default, the exports are stored in an automatically created Export folder below the %MINDSERVER_PROJECTS%\singleMindServer.<index engine name> folder.
