Production Rules: Things to Consider
When working with production rules, consider the following:
- A production rule has no effect until it has been added to a production workflow.
- Once a production workflow is used to create a production set, its rules cannot be modified. If a subsequent production requires rule modification, you must create a new rule, delete the original rule from the production workflow, and then add the new rule to the workflow as a replacement.
Changing the name of a production workflow also changes the names of that workflow's default production rules. It takes a couple of minutes for this change to become visible.
