Viewer Limitations
- Page navigation
- Regardless of your Page Layout setting on the User Preferences page, Text view always uses page mode navigation, as does Near Native view when you view a document that contains more than 500 pages.
- Very large documents
- For converted documents, besides the actual document rendition, the viewer requires meta-information for each page and a text index with words and positions to provide search within the document, highlighting and interactive search-based redaction.
- When you view very large documents in Redaction view, the amount of data sent to the browser is limited to prevent out-of-memory errors. This results in the following limitations:
- The text index created during conversion gets dropped. A warning message displays at the top of the viewer panel to notify you this has occurred.
- Document search in Redaction view, highlighting and interactive search-based redactions are also disabled. You can still view and redact the document manually and use global redaction.
Tip: To proactively locate the affected documents and optionally segregate them for review, use the Conversion Smart Filter. The documents are flagged Converted - Text index dropped.
