Influence Search Result Order with Boolean Operators and Asterisk
You can combine the asterisk with Boolean Operators in order to influence the Results list ranking.
- Example:
Gardening OR *
- Finds all documents, but scores are higher for documents containing Gardening.
* OR Gardening
has the same result. - Example:
Gardening AND *
- This would not be used, as the search result is exactly the same as for the search:
Gardening
