Bulk Tagging
Bulk tagging is the process of tagging multiple documents simultaneously.
To bulk tag documents:
  1. Select the documents to be bulk tagged.
  2. Apply the desired tags using the Bulk Tagging panel. (Tri-state mode is activated for single value, multi-value and hierarchy fields.)
  3. Click Save.
If you select documents and the Bulk Tagging panel is not active, activate the panel using one of these methods:
  • In the Results list, click once somewhere within the row of the document you are currently viewing, to unhighlight the document without selecting it.
  • Move to one of the selected documents, so you are actively viewing it.
    Caution: If you click the Edit button in the Tagging panel, the document you are currently viewing will be auto-selected.
Bulk Tagging Panel
 Related:
Document Selection
Tri-state Mode
Bulk Tagging Text Fields
Tagging Rules and Bulk Tagging
