Predictive Coding
Predictive Coding supports the review process by automatically identifying possibly relevant documents and analyzing the review progress.
Predictive Coding can be used to analyze the progress of a review workflow or of a universe. For analyzing the universe review progress, Predictive Coding counts the documents confirmed for the field value of the target workflow and compares them with the default sample.
Possibly relevant documents are automatically identified through iterations. With every iteration set, new relevant universe documents are proposed for a workflow and made available for review. Non-relevant documents are ignored. This allows reviewers to concentrate on documents that are most likely to be relevant.
The Predictive Coding process is visualized on the Predictive Coding Dashboard.
User activities related to Predictive Coding are logged in audit log files.
