Undo or Delete Redactions
You undo or delete redactions in the viewer’s Redaction view.
To undo the last applied redactions, press CTRL+Z one or multiple times, until all undesired redactions are gone. Redactions that were created in one step are removed in one step.
Tip: If you have created a redaction just before, and the redaction button used is still active, you may have to click on another button, before using CTRL+Z.
To delete one occurrence of a specific redaction, click
and right-click on the
redaction. From the context menu, select
Delete.
