Group Documents Within Batches
Note: If associated documents are included for batching, document grouping works differently. See: Include Associated Documents.
You have the option to group documents within review batches by the values of the Data Source, Custodian or Document Date fields.
When you opt to group documents, the system first sorts the document set by the selected field’s values, either alphabetically or by date, and then adds them to batches as specified by the remaining batch settings.
There can be several batches for the same field value and a single batch can contain documents for different field values.
