Conversion Smart Filter
The Conversion Smart Filter shows the results of conversion for production and for the viewer's Redaction view. A document can have multiple values in this Smart Filter.
If a user opens the Redaction view of an unconverted document, this document is converted on-the-fly. This creates, amongst others, a display file for Redaction view which is only stored in a cache, and, after a certain time, will disappear from this cache. The Smart Filter does not track such temporary display files. Also, for printing from Redaction view, only XDL file creation is tracked as Converted - Prepared for Production.
Value | Description |
No Value |
There is no imported image or conversion has not yet taken place. |
Converted - Prepared for Production |
If you want to create image productions, every document needs this value. A document is assigned this value:
Converted- Printed Native |
Native file (no image or slip-sheet) has been successfully converted for production. User printed the Redaction View using Print in the Results list Actions menu, or bulk conversion for redaction/production was run, or user opened the Redaction view and created a display file on-the-fly. |
Conversion exception |
Conversion failed. Instead of the document content, a slip-sheet is shown in Redaction view. This slip-sheet can be used as production image. If conversion fails and no slip-sheet can be created, the document is not assigned this value, but the Converted - Display Exception value. |
Converted - B&W |
This value can be assigned to a document with a black and white overlay image imported using CSV Merge or CSV Load. This value is also used by a legacy black and white conversion. |
Converted - Color |
This value can be assigned to a document with a colored overlay image imported using CSV Merge or CSV Load. This value is also used by a legacy color conversion. |
Converted - Color mode unknown |
This value can be assigned to a document with an overlay image imported using CSV Merge or CSV Load and for which the color mode has not yet been detected. This value also occurs for legacy conversion results. |
Converted - Empty pages were removed |
This value was only used by the legacy conversion. Empty pages were removed from conversion results for specific MIME types. |
Converted - Fallback to Stellent applied | This value was only used by the legacy conversion if your system is especially configured to use Oracle Outside In conversion after native conversion failed. As document conversion was successful, documents with this value are also tagged with Converted - B&W or Converted - Color. |
Converted - Native | Document was successfully converted using native conversion, that is, PDF creation of the respective Microsoft Office application. |
Converted - Page limit reached |
This value was only used by the legacy conversion. It was assigned if a successfully converted document exceeded the configured page limit. |
Converted - Prepared for Redaction View |
Document is ready for display in Redaction view. Note that you do not need this value to be able to redact documents, as users can convert documents on-the-fly by clicking the viewer's Redaction tab. This value is assigned to a document
Converted - Slip-sheet | Assigned to documents for which an exception slip-sheet has been created. |
Converted - Text index dropped |
This is a very large document for which the viewer text index has been dropped to prevent viewer errors. No search or highlighting is possible in the Redaction view. Users can switch to Text view to run a search and see highlighting. |
Converted - Text index truncated | This is a very large document for which the viewer text index has been truncated to prevent viewer errors. Users can switch to Text view to run a search and see highlighting. |
Converted - With warnings |
Assigned to every document converted with any warning. The field value displays the total number of the documents converted with warnings. |
Converted - With other warning | Assigned to a document when the system cannot assign any of the other, more specific warnings. |
Converted - With warning chart(s) missing | Assigned to protected Microsoft Excel documents when the unhide charts action was not executed. |
Converted - With warning content is missing | Assigned to a document
when:
Converted - With warning content is potentially missing | Assigned to a document
when:
Converted - With warning formatting is unexpected | Assigned to a document
when:
Converted - With warning review information is incomplete | Assigned to protected Microsoft PowerPoint documents when printing comments was requested but did not happen. |
Display Exception |
Assigned to documents when conversion fails and a slip-sheet cannot be generated, which may occur when:
Imported image |
This value is set for a document image that was imported by an Administrator using CSV Load in Axcelerate Ingestion or CSV Merge in Axcelerate Ingestion or Axcelerate Review & Analysis. Documents with imported images are automatically tagged as Converted - Prepared for Production. |
Reconversion needed - Native document Updated |
If you see any number for this value in the Smart Filter, filter for it and check the documents found. This value is assigned to a document that was converted and then, due to a change to the original document, reloaded into Axcelerate Ingestion and republished. |
