Native View Preparation Smart Filter
The Native View Preparation Smart Filter reflects bulk conversion results for Near Native view. A document can have multiple values in this Smart Filter.
If a user opens the Near Native view of an unconverted document, this document is converted on-the-fly. The conversion result is only stored in a cache, and, after a certain time, it will disappear from this cache. The Smart Filter does not track such temporary display files. Also, printing from Near Native view is not tracked.
Value | Description |
No Value |
Document is not tagged with any of the below values. |
Converted - Native | Native file is a Microsoft Office document. It was successfully converted into a PDF file using native conversion. |
Converted - Near Native |
Document was successfully converted into a PDF file, for viewing in Near Native view. Such a conversion is also started when you print the Near Native view using the Actions menu above the Results list, or when you create annotations in Near Native view. |
Converted - Prepared |
Document or conversion exception slip-sheet is ready for viewing in Near Native view. |
Converted - With warning formatting is unexpected | Assigned to a document
when:
Converted - With warnings |
Assigned to every document converted with any warning. The field value displays the total number of the documents converted with warnings. |
Conversion exception | Conversion failed. Instead of the document, a slip-sheet is displayed in Near Native view, informing you that "Document could not be rendered." |
Converted - Based on Image |
Native file is an image. During bulk conversion it was assigned this value, as images do not need to be converted into a PDF file for Near Native view. |
Converted - Empty pages were removed |
This value was only used by the legacy conversion. Empty pages were removed from conversion results for specific MIME types. |
Converted - Page limit reached |
This value was only used by the legacy conversion. It was assigned if a successfully converted document exceeded the configured page limit. |
Converted - Slip-sheet |
Assigned to documents for which an exception slip-sheet has been created. |
Converted - With other warning | Assigned to a document when the system cannot assign any of the other, more specific warnings. |
Converted - With warning chart(s) missing | Assigned to protected Microsoft Excel documents when the unhide charts action was not executed. |
Converted - With warning content is missing | Assigned to a document
when:
Converted - With warning content is potentially missing | Assigned to a document
when:
Converted - With warning review information is incomplete | Assigned to protected Microsoft PowerPoint documents when printing comments was requested but did not happen. |
Reconversion needed - Native document Updated |
Assigned to a document that was converted and then, due to a change to the original document, reloaded into Axcelerate Ingestion and republished. This value is not shown for documents converted on-the-fly and that have no annotations. |
