Search Within a Document
The Viewer panel contains a search bar that allows you to search within a single document.
How to Use Document Search
To search within a document:
  1. Open the Viewer panel.
  2. In the toolbar, type a keyword or phrase into the Document search box and hit Enter to run the search.
The query is applied to the text of the document and its metadata. The hits are highlighted in the document and in the Metadata panel. To jump between the hits, use the previous and next arrows, located to the right of the Document search box.
Tip: Document search highlighting must be enabled for the terms to be highlighted in the respective view. See: Adjust Viewer Highlighting
Tip: In Near Native, Redaction and Productions view, click , located to the right of the Document search box, to access a search results overview that displays hits in context. You can then click on any row of the overview to jump directly to that hit.
How Document Search Works in the Different Document Views
Document search in Text, Near Native and Productions (Text/OCR) view works in the same way as the search in the Results list. Only document search in Redaction view is different, due to the special technology required for Redaction view display.
Tip: If you wonder why a document was found via the search in the Results list, but the respective item is not highlighted in Redaction view, look at the Text view.
Document search settings are kept when you switch between documents or between views.
It may happen that a search created in Near Native, Productions or Text view is incompatible with Redaction view and vice versa. For example, the wildcards * and ? do not work for a search in Redaction view.
The list below describes the main differences between using Document search in Text, Near Native or Production view versus Redaction view:
Document Viewer Highlighting
Copyright © 2019 Open Text. All Rights Reserved. Trademarks owned by Open Text.
